Speedy-Konkurrenz? "Ball"
Neu von "Ball"
(c) Timezone.com
For Baselworld 2006, Ball Watch will introduce the Fireman Ionosphere Chronograph which marks the beginning of their collaboration with engineer and NASA astronaut Dr. Owen Garriott, who first launched into space as the scientist-pilot for the Skylab III mission.
Drawing on his space experiences, as well as extensive time spent on deep sea research missions and Antarctic expeditions, Dr. Garriott has worked with the Ball Watch designers to create the specifications for this professional watch.
"In space, accurate time is even more important than on the ground," Garriott stresses. "As the spacecraft moves at about 7.5km/sec, every second of error moves your landing point by 7.5 km." An early astronaut quickly learned this when he delayed the deorbit burn too long and landed far from his intended splashdown point.
The case, in stainless steel, measures 43mm X 14.4mm and has an AR coated sapphire crystal, screw-down crown and back, and is water resistant to 100 meters and schock resistant to 5,000 G’s.
Movement is the automatic ETA caliber 7750, functions include the hours, minutes, subsidiary seconds; day and date; chronograph – accumulated time measurement up to 12 hours; 19 micro gas tubes on the hour, minute, and second hands and the dial for night reading capability.
A white dial is also available.
(c) Timezone.com
Marketing-Schmäh vom Feinsten."In space, accurate time is even more important than on the ground,"
Re: Speedy-Konkurrenz? "Ball"
Hi,
Neil: "Jungs, Zeit zum Wiedereintritt, zünd mal wer die Raketen!"
Edwin: "Kann grad nicht, bin auf dem Klo."
Michael: "Nicht mein Job, mach das selber!"
Neil: "Wer von euch Chaoten hat da wieder seinen Helm auf die Armaturen gelegt? Ich komm nicht an den Knopf..:"
Neil: "EDWIN! Zwick ab, wir müssen runter!"
Edwin: "Mann! Drück einfach wer C-17, B-2 und zieht *kurz* an DF-C7"
Neil: "..............Done"
Edwin: "NICHT SO LANG, DU IDIOT!"
Michael: "Ich kann die Pyramiden sehen"
Base Control: "Sagt mal, was macht ihr da? Die Temperatur eures Hitzeschildes ist 700 Grad zu hoch!"
Neil, Edwin und Michael im Chor: "Schnauze da unten!"
Und so starben drei junge, mutige Astronauten...
Andi,
der nicht wirklich glaubt, dass die irgendwas mit ihren Armbanduhren getimt haben...
neulich beim Wiedereintritt:kochsmichel hat geschrieben: An early astronaut quickly learned this when he delayed the deorbit burn too long and landed far from his intended splashdown point.
Andi,
- Crusader
Na ja, wer tritium vials kennt, weiß sie zu schätzen, und im vergleich zu den oft barocken Produkten von Ball sieht diese Uhr immerhin halbwegs geradlinig aus.
Das Marketing-Gesülze ist quatsch, ändert aber nichts an der Nützlichkeit der tritium vials. Die bestimmen die Attraktivität der Uhr (oder schrecken ab, je nach Geschmack ), und nicht die pseudo-Connection mit der Raumfahrt. Da haben weiterhin Speedy, X-33 und andere die Nase vorn.
Guckst du mal "Apollo XIII".Grantler hat geschrieben:der nicht wirklich glaubt, dass die irgendwas mit ihren Armbanduhren getimt haben...
Aber bis es so weit kommt ist "ziemlich alles" ausgefallen.
Hi,
Der Grat zwischen Abprallen und Verglühen ist ziemlich schmal...
hab ich gesehen/vorher schon geusst. Die haben in einer extremen Ausnahmesituation *einmal* was von Hand getimt. Mit einer Chance, es zu überleben, die wahrscheinlich im Promill-Bereich lag (was aber nach den vorangegangenen Ereignissen eh schon wurscht war).jeannie hat geschrieben:Guckst du mal "Apollo XIII".Grantler hat geschrieben:der nicht wirklich glaubt, dass die irgendwas mit ihren Armbanduhren getimt haben...
