Microbrand Uhren Sammelthread
Re: Microbrand Uhren Sammelthread
Eightdynamics ist hoffentlich eine Zweitmarke von Sevenfriday. Ansonsten würde ich das nämlich etwas dreist finden, selbst wenn ich nicht jede Hommage verurteile...
https://www.sevenfriday.com/en-de/home
Balticus Grey Seal
http://www.balticus-watches.com/
(c) von ebenda:
(c) von ebenda:
Preis: 1500 PLN = ungefähr 350 EuroBalticus a typical Microbrand first debut model was named the Grey Seal. That is why the case back of the watch was decorated with printed gray seals which is excellent diver. Grey seals are able to descend to a depth of 200 m, but also registered immersion for more than 300 m.
The mechanism of a watch Grey Seal is an perfect Japanese Miyota 9015 manufactured by Citizen, bearing on 24 stones, partly decorated with the Geneva stripes, back decorated with Balticus name. It went a sapphire anti-reflection (inside), rotating bezel has also been placed inside the watch. To keep the class of water resistance WR300 crown is screwed. Grey Seal included a mesh bracelet but also a stylish leather strap with stitching matching color dial.
Orologi Calamai
http://www.orologicalamai.it/
z.B.
(c) von ebenda
z.B.
(c) von ebenda
Cronografo 42,5 mm. diametro della cassa
Pulsanti a sinistra.
Quadrante antracite con contatori “oversize” dei minuti ed ore cronografo di colore nero opaco contornati di colore rosso, contatore secondi nero opaco.
Movimento Valjoux 7750 Controllato e regolato a montaggio effettuato.
Cinturino in acciaio o pelle.
Impermiabile fino a 5 atm.
Die Hager Aquamariner
http://oceanictime.blogspot.co.uk/2016/ ... riner.html
(c) von ebenda/http://www.hagerwatches.com/
Estonia 1918 Woitleja
http://www.wristwatchreview.com/2016/08 ... -woitleja/
(c) von ebenda
(c) von ebenda
Preis: 900 DollarTech Specs from Estonia1918
Material: CuSn8 Bronze
Diameter: 44mm
Thickness: 11 mm
Sapphire Crystal
Strap width: 24mm
Screwdown Strap Bars
Brushed + Polished Finish
See-through Sapphire Caseback
Movement: upgraded Unitas 6497-2
Die gefällt mir.kochsmichel hat geschrieben:
Finde da aber keinen Preis?
Um die 4600 Euroalinghi74 hat geschrieben:Die gefällt mir.kochsmichel hat geschrieben:
Gruss,
Alexander
Alexander
Ui!Alex1974 hat geschrieben:Um die 4600 Euro
Der Preis ist aber nicht Micro...
Danke Alex.
kochsmichel hat geschrieben: Haue hier auch nur rein, was ich einigermaßen interessant finde.
Echt jetzt?
Neee...nicht diese Art von "interessant" Dis ist halt interessant, weil sie irgendwie "abgedreht" ist.... Oder die Aquamariner. Die ist "interessant", weil..nun ja, sie ähnelt ein wenig...komm gerade nicht drauf...Maximus82 hat geschrieben:kochsmichel hat geschrieben: Haue hier auch nur rein, was ich einigermaßen interessant finde.kochsmichel hat geschrieben:
Echt jetzt?
https://www.hodinkee.com/articles/octav ... illa-watch
Octavio Garcia Gorilla Watch
https://hodinkee.imgix.net/uploads/imag ... 6/hero.jpg
Karbon und Keramik für 1.000,- CHF
Ich hab nirgendwo gelesen, was da für ein Werk drin ist...Mechanik?
Hat irgendwie was... muss irgendwie an SevenFriday denken. Aber mit den drei Zeigern aus der Mitte stelle ich mir die Ablesbarkeit im realen Leben etwas schwierig vor...
Guckst Du hier:stere hat geschrieben:Karbon und Keramik für 1.000,- CHF
Siehe auch: http://www.fratellowatches.com/gorilla- ... irst-look/If corners have been cut anywhere, you could say they've been cut in the movement, which is a Miyota 8125.
(c) von ebenda:
Zuletzt geändert von kochsmichel am 30 Aug 2016, 11:12, insgesamt 1-mal geändert.
